Fuel gauge not working in 97 4Dr 4x4
Old Jan 17, 2012 | 08:56 PM
jward2155's Avatar
jward2155 is on a distinguished road
Default Fuel gauge not working in 97 4Dr 4x4
I just had to replace my fuel pump because it wasn't working but now my fuel gauge dont work. When I turn the key the gauge jumps to full then stays on E for the remainder of the time that the ignition is on I've read that I may need to replace the wire connector that goes to the sending unit, the old wires plugged right up so i didnt think of it, do I have to replace the connecter in order for the aftermarket fuel pump to tell me how much gas I have?, i also had the filter replaced, it runs fine just dosent tell me how much gas i have I have no idea any help would be appreciated
Old Jan 18, 2012 | 06:14 PM
step66's Avatar
The fact that the gauge ramps up to full should indicate a good connection,even though it then dies. Something fishy here! You DID replace the pump and float assembly as a whole,correct? If not,that may be the issue! The manufactuer of the pump is also critical! Hope you paid good $ for a quality pump,or else you got what you paid for! One can't cut corners here! One HAS to go with the hi-$ pumps from reputible sources,no other way...
IMO! step66
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
Karen Beech
Dec 10, 2013 04:59 PM
mjw1991
Feb 24, 2013 10:18 PM
Mulisha
Mar 24, 2008 09:14 PM
