fuel gauge reads more than full
Old Jun 1, 2009 | 12:32 PM
chipo022's Avatar
chipo022 is on a distinguished road
Default fuel gauge reads more than full
i guys i just bought an oldsmobile ravada 97 wth the 4.3 engine. Im havingthis problem with my gauge always reading more than full tank, i tried disconecting the fuel sender unit to check if it was the floater thing but evend do i disconnected everything even the fuel pump the gauge goes up. Im erally lost here so any input would be greatly appreciated. thanks
Old Jun 1, 2009 | 01:14 PM
Your gauge could be bad or you could have a bad wire between the sender and the PCM/BCM.
Old Jun 1, 2009 | 01:24 PM
chipo022's Avatar
i already replaced the istrument panel and it does the same thing. how do i check for a bad wire.. do it do it just phisically or check resistance??? where is the ecm or pcm that you mentioned
so i found some more symptoms... if you turn off the car the needle goes to like 1/4 of gauge but *** soon as you start the car the needle goes up.
Old Jun 1, 2009 | 03:12 PM
I would check continuity to ground. I do not have access to the proper wiring diagrams at this very moment and likely will not get to them anytime today. Hopefully someone else has them handy...
*EDIT* - please find the images below:
Blessed23
Sep 27, 2014 06:50 AM
BlakeM
Jun 23, 2011 06:18 AM
fallen4her02
Apr 24, 2011 09:37 AM
Olds Guy
Nov 11, 2010 09:21 PM
blazerguy22
Dec 12, 2008 07:59 PM
