Fuel Injection Upgrade?
Old Jun 3, 2013 | 02:46 PM
chris015's Avatar
thats about right. I wouldnt worry about it untill you have issues. Once that time comes,everything is plug n play with the new bracket. Hardest part is getting the manifold seated. I did one on a astro van.
Old Jun 3, 2013 | 07:22 PM
LeWhite's Avatar
Heard you have to lube the O ring on the injector body.
Old Jun 3, 2013 | 10:37 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
Could the bracket and injectors b taken from a newer blazer with the vin x?
Old Jun 4, 2013 | 01:54 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
True. If you don't put a little clean engine oil on the O-ring that seals the injector body it can tear.
Old Jun 4, 2013 | 01:06 PM
Yup, no problem.
Old Jun 4, 2013 | 02:29 PM
4X4GS10B's Avatar
Originally Posted by Captain Hook
Yup, no problem.
thank you sir, that's all I needed to know. pick-n-pull here I come...
Old Jun 4, 2013 | 02:37 PM
phxjosh's Avatar
phxjosh is on a distinguished road
Nice, good to know as well I might try that.
Old Sep 19, 2013 | 11:50 AM
smokii's Avatar
smokii is an unknown quantity at this point
1996 and newer 4.3L engines, (8th character of the VIN must be "W") use 6 injectors centrally located in the plenum. There is a nylon fuel line connected to each injector for each cylinder. At the end of each line there is a poppet valve with a nozzle that attaches to each intake port. Over time, the poppet nozzels get restricted or leak fuel, or both. The assembly looks like this:
The new design eliminates the poppet valves and relocates the injectors to the intake ports. Fuel mileage and performance are both improved slightly with the upgrade. If the 8th character of the VIN is "X", the engine already has the upgraded injector assembly. The new design looks like this:
The assembly is available at most auto parts stores, as well as Amazon, Ebay and other online sources, usually for under $200. The Delphi part # is FJ10565 and comes with the necessary bracket. An upper intake gasket set is also necessary to complete the job. With a little practice, the job can be done in under 2 hours using common hand tools. No reprogramming of the PCM is necessary, plug & play.
Captain, I have a 1995 Blazer and I figure my terrible performance and the sucky running is due to the injection. tell me, can I get the upgraded spider for my year? My truck has a 'W' in the 8th position also. The funny thing about this truck is that it is a 1995 model yet has the OBDII plug under the dash rather than the OBDI as specs call for and NO mechanic or parts person I talk to believes til they see it. They always assume I'm an idiot and know nothing about anything. Not a mechanic but have kept everything running for me and other family for 20+ years.
Attached Thumbnails Fuel Injection Upgrade?-oldstylecsfi_zps22da5ee9.jpg   Fuel Injection Upgrade?-acdelco217-3028.jpg
Old Sep 19, 2013 | 01:20 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Your truck is a CPI injected truck, which uses a different fuel injection setup than the 96+ trucks.
Yours is like this
GB Reman 833 22101 Fuel Injector Remanufactured CPI Fuel Injector Assembly | eBay
Attached Thumbnails Fuel Injection Upgrade?-%24t2ec16r-ce9s4pth6kbr-muqk-gw%7E%7E60_12.jpg   Fuel Injection Upgrade?-cpi.jpg   Fuel Injection Upgrade?-12900_cpi3_1.jpg
Old Sep 19, 2013 | 04:22 PM
...The funny thing about this truck is that it is a 1995 model yet has the OBDII plug under the dash rather than the OBDI as specs call for and NO mechanic or parts person I talk to believes til they see it...
Early 95 had CMFI with OBDI engine controls. Mid 95 had CMFI with OBD1.5 engine controls. Not fully OBDII compliant, but it did give DTC's starting with "P". The PCM used a different protocol and requires unique software in the scan tool to retrieve DTC's, (not all scan tools will communicate with it). There are a few, (very few) late 95's that had CSFI and were fully OBDII compliant. All of this confusion is one of the reasons that Oldsmobile did not produce the Bravada in 1995.
Kilo
Jul 26, 2013 07:21 AM
gregl316
Mar 29, 2011 07:06 PM
longslide
Nov 26, 2009 05:01 AM
SlydinClyde
Oct 20, 2009 12:56 AM
scn1010
Engine & Internal
Jan 19, 2006 10:56 AM
