Fuel injectors
Old Oct 9, 2005 | 04:57 PM
mytruck2's Avatar
mytruck2 is an unknown quantity at this point
Default Fuel injectors
Can anyone give me a rough price on how much it cost them or does cost to have fuel injectors replaced? Everything in my Blazer has been replaced or fixed, fuel wise and it still will not start. I think one or some of the fuel injectors may have gone and trying to ge a rough estimate before it gets sent off to the mechanic. Thanks! 4.3l 6 cyl Vin (W)
Old Oct 10, 2005 | 12:45 AM
LoLoS10Blazer87's Avatar
LoLoS10Blazer87 is an unknown quantity at this point
Default RE: Fuel injectors
A) This should be in the General Tech forum
B) Fuel injectors may not be your problem. They don't usually go out all at once. Is the truck getting spark? Check the cap, rotor, plugs, wires, and coil. Check the crankshaft position sensor. Make sure you've got good compression on all cylinders.
If you do need new injector(s), they usually run about $80 at an auto parts store. A mechanic may quote you a higher price.
Ryan D
Oct 25, 2010 02:00 AM
riverjamie
Sep 25, 2007 10:24 AM
booblinker
Engine & Internal
Oct 16, 2006 05:05 PM
mregulater
Apr 3, 2006 01:07 PM
matt_87_s10_blazer
Jan 26, 2006 09:02 PM
