Fuel injectors harness stuck open
Old Sep 25, 2018 | 01:57 PM
Gizmorph's Avatar
Gizmorph is on a distinguished road
Default Fuel injectors harness stuck open
Need help bad, first of my 2000 Chevy blazer Is a 4wd 4.3 4door. It has a misfire on po302 and po452 evap code. When testing injector harness while cranking the motor, test light don’t blink on any injector. Just stays lit. Need help trying to figure out why its not pulsing like it’s supposed to. Any help is great appreciated in advance.
Old Sep 26, 2018 | 11:14 AM
LesMyer's Avatar
With key on, 12v constant is supplied to injectors. Injectors are then activated by the PCM grounding each circuit.
does that help? Are you using a noid light or a test light? If using a test light, what is opposing end connected to - power or ground?
Old Sep 26, 2018 | 04:35 PM
Gizmorph's Avatar
Default 2000 Blazer
I am using a test light connected to the alternator housing. Thank you for your help.
Old Sep 26, 2018 | 07:34 PM
LesMyer's Avatar
Light is not pulsing because you are probing the continuous 12v power to the injectors. Please get a noid light that will fit your injector harness plug between the two terminals for each injector.
Gizmorph
Sep 25, 2018 10:10 AM
Gusman
Jan 19, 2013 09:06 AM
moseph78
Jul 7, 2011 06:16 PM
nate_v8
Jun 17, 2011 11:47 AM
aspenpup
Engine & Internal
Apr 3, 2007 09:50 AM
