fuel leak
Old Nov 8, 2011 | 08:34 PM
shadow007200's Avatar
shadow007200 is on a distinguished road
Default fuel leak
i got a 1996 chevy blazer with a fuel leak right at the tank im not totally sure if its the line that connects to the sending unit or the sending unit itself
Old Nov 8, 2011 | 08:50 PM
Kknd310's Avatar
Kknd310 is on a distinguished road
wheres the leak at again? the tank it self? front? rear?
Old Nov 9, 2011 | 10:58 AM
Default fuel leak
The fuel leak is from the front of the fuel tank. Hopefully i can get pointed in the right direction for this thing
Old Nov 9, 2011 | 11:07 AM
Tubais's Avatar
Tubais is on a distinguished road
The blazer i just bought has a fuel leak also... what i found was the vent leaking when i over filled it.. My tank is metal so it is replaceable not sure about yours..
good luck
Old Nov 9, 2011 | 09:52 PM
Easy48827's Avatar
Easy48827 is on a distinguished road
The leak is probably from the vent valve (part of emissions system). It's common for the vacuum hose to become detached when removing the tank. It's also possible to break the plastic tube the hose attaches to. If the leak is coming from the front it is either that or a rust hole. Also, be advised, the fuel lines run along the top of the frame and don't get the gunk washed off over the years and eventually rust out. If the leak happens only when the ignition is on, you have a hole in your fuel line. My "96 developed a leak aft of the fuel filter after service. I bypassed the rusted line with high pressure rubber line from Car Quest.
Old Nov 9, 2011 | 10:05 PM
Kknd310's Avatar
agreed, the vent valve at the front, mine was leaking. needed a new gas tank since the plastic ones are made in a way where you cannot replace the valve ( atleast i couldn't figure out how ) if its a metal tank it should just unscrew
Big Eazy
Apr 27, 2013 12:48 PM
BubbaBrooks
May 18, 2011 08:38 PM
abadinalbany
Jun 1, 2009 08:27 PM
TAZ454
Jan 28, 2008 10:11 AM
