fuel line leak
Old Jun 19, 2012 | 09:26 AM
jim109's Avatar
jim109 is on a distinguished road
Default fuel line leak
I have a fuel leak on my 99 blazer 2dr right over the tank it looks like a steel line is rusted out .Before i drop the tank i would like to buy new lines.Do they come in standard lenths or sets or replacement pieces? Thanks Jim
Old Jun 19, 2012 | 01:22 PM
4x4blazerguy's Avatar
I would say check with different parts suppliers. Also check GMPartsShop.com, & RockAuto.
Old Jun 19, 2012 | 03:33 PM
The pressure line is 3/8" and the return is 5/16". You can use compression fittings and steel brake line to repair it. Very inexpensive way to repair it. Compression fittings are rated at 170psi, maximum fuel pressure is 108psi.
Old Jun 20, 2012 | 05:26 PM
jim109's Avatar
Thanks.. I would like to see what the connections look like on top of tank
where plastic lines from pump connect to steel lines . Cant find a pic or diagram. Thanks Jim
Old Jun 20, 2012 | 05:45 PM
You won't find a picture like that The module connection is plastic and the line is plastic with an elbow on one end, and a straight fitting on the module end. The plastic line, (elbow) connects to the steel line just above of the tank, about 6" from where your line rusted out. Most auto parts stores have it,
Buy Dorman - OE Solutions Steel Fuel Line Assortment 1 Each: 5/16 and 3/8 Inch x 12 Inch Double Bead Lines 800-159 at Advance Auto Parts_____
Cut the tube right next to one of the beads, bend the tube to fit and stick a compression fitting on.
95jblaze
Aug 27, 2011 03:46 PM
jlow10
Mar 10, 2011 11:15 AM
Fossil Rock
Jan 5, 2009 09:16 AM
pilgrim
Engine & Internal
Nov 14, 2006 02:06 PM
