fuel pressure problem
Old Aug 21, 2007 | 06:46 PM
adlady's Avatar
adlady is an unknown quantity at this point
Default fuel pressure problem
I really need some advice here. I have a 2000 blazer 4dr 4wd. 4.3
My brother is willing to work on my car, he is a FORD man and chevy is not something he likes
does anyone have pics of the fuel relay or fuel pump location?
the car won't start and there is no pressure in the fuel rail
(HELP)
[align=left] [/align]
Old Aug 21, 2007 | 07:27 PM
Default RE: fuel pressure problem
The fuel pressure relay is located in the underhood fuse box. Just look at the listing which will refer to the diagram which will lead you to the fuel pump relay itself. The fuel pump is located in the fuel tank and requires dropping the tank to take out.
I recommend that you check all of the fuses. The fuel pump relay should be the same as atleast one other relay in the box. I believe it's the same as the horn relay and if you swap them and the horn works, the relay is doing its job. Then, you have to check and make sure that the relay is getting the proper signal from the PCM to turn on. This is accomplished by makeing sure that there is 12V on pins 30 & 85 (I think) and ground on 86... Or is it ground on pin 85 and 12V on pin 86... It really doesn't matter, but both should be present with the key on (but may go away after 10-20 seconds when the PCM shuts off the feed). Just check it both ways. If you don't have 12V to pin 30, then you probably have a faulty fuse.
If all of that checks out, then the next course of action would be to pull the electrical connection off of the fuel pump and test for power and ground at hte pump.
Old Aug 21, 2007 | 08:07 PM
adlady's Avatar
Thank You!
My brother wants to know if by any chance they might have made it a little easier and put in an access panel through the floor board?
Old Aug 21, 2007 | 08:39 PM
Would be nice, but I would have told you if they did...
Old Aug 25, 2007 | 03:13 PM
adlady's Avatar
Hey I just wanted to tell you THANKS for your advise....
My brother got my car fixed and its running fine now.....
What a job it was....
Thanks again, Linda
Old Aug 25, 2007 | 05:29 PM
I am very glad that you and your brother were able to repair your truck!!
Old Aug 26, 2007 | 01:35 AM
aspenpup's Avatar
aspenpup is an unknown quantity at this point
What turned out to be the problem?
racinghoss
Sep 10, 2023 08:56 PM
friedaddy
Apr 25, 2011 11:22 AM
Bad Ramer Jamer
Sep 16, 2008 10:32 AM
Spartan66
Jul 11, 2008 02:34 PM
gpr13902
Apr 29, 2008 10:12 PM
