Fuel problem
I've got s 99 Blazer LT. This weekend it died on me, kind of sputtered to a halt. Compression test was good, thank god. Fuel filter replaced. I can hear the fuel pump prime, and continue to run while i crank the engine. I tested the pressure in the fuel line. The book says i should have 50-60 psi. I have only about 30 psi. Is this a clear sign of a bad fuel pump, and if so, why are my fuel pumps going bad because i've already replaced it twice. If it's not the fuel pump, what is it? Any sugestions?
Yea, I believe you need at least 50 psi to start/run. I've heard discussions where if you let the tank get below 1/4 tank or run out of gas completely it can lead to premature failure. I'm not sure if this is true or not, but I've never let those circumstances happen to me and my fuel pump is still going strong.
Bought a new distributor cap and rotor, and added another gallon of gas, and POW,fired right up. Really can't imagine that either or both of those things were holding me back, but I'm back in business and that's all that matters.
vansoffthewall53
Sep 2, 2014 09:31 PM
95jblaze
Aug 27, 2011 03:46 PM
English5
Jul 16, 2010 11:11 AM
Confuused69
Aug 2, 2009 11:53 PM
Daytripper540
Mar 29, 2007 03:54 PM
