fuel problem?
1999 blazer 4.3 bog with acceleration. new pump, fuel and air filter, fuel regulator. Revs up fine until its put in drive. It will bog a little at first and get worse quickly. I have to baby the pedal to get to speed. Until it's so bad I need to pull over and shut it off for a few and start all over. ????
It could also be a plugged catalytic converter. If your truck is/was running rich it could have fouled the cat, or caused it to start breaking down. You can test this by removing the upstream O2 sensor and driving with it out. If the problem gets better then you know you need to replace the cat.
vansoffthewall53
Sep 2, 2014 09:31 PM
95jblaze
Aug 27, 2011 03:46 PM
English5
Jul 16, 2010 11:11 AM
Confuused69
Aug 2, 2009 11:53 PM
Daytripper540
Mar 29, 2007 03:54 PM
