fuel problem with fill
Old Oct 28, 2009 | 10:28 AM
mikegav's Avatar
mikegav is on a distinguished road
Default fuel problem with fill
hello im new here so i have a 2002 s-10 blazer 4wd and what has been happening is when i go to put fuel in it takes forever seems like there is something clogging the filler neck ive never had this problem with any other vehicle i owned truck runs fine other then when i have to put gas in any ideas thanks again mike
Old Oct 28, 2009 | 10:48 AM
Monkeyman's Avatar
Monkeyman is on a distinguished road
I have a similar problem. When I fill it up, the auto shut off at the pump (any pump) doesn't work and gas will run out of the fill tube. I have to listen very carefully to make sure I stop the pump just before it fills completely. I'm guessing it's a blockage in the vent tube. That might be your problem, too.
Old Nov 1, 2009 | 02:04 PM
mikegav's Avatar
Default no vent problem
checked no problem with the vent just dont understand it
Old Nov 1, 2009 | 09:21 PM
Blazeme's Avatar
Blazeme is on a distinguished road
I had some trouble like this a few years back on my 01 Blazer. I replaced a solenoid, I think it is in one of the gas tank vent or purge lines. It was located in front of the spare tire.
I could not tell if it was hanging up or what. It seamed to be free to move inside and I thought it should be ok so I put it back. The tank still filled slow so I purchased a new one. After I replaced it the tank has filled normally ever since.
It is baffled to keep water out but were it is located it looked like it gets a lot of trash splashed on it.
Hope this helps
Blazeme
Old Nov 3, 2009 | 11:21 AM
mikegav's Avatar
thanks blazeme ill try this let you know outcome thanks again
BlazinMike89
Oct 18, 2009 03:39 PM
fredgie7
Mar 27, 2009 11:27 AM
dgastone
Sep 29, 2008 12:00 PM
dgastone
Sep 29, 2008 10:17 AM
filstoy
Apr 16, 2007 10:25 PM
