Is this fuel pump any good?
Old Jan 21, 2013 | 12:47 PM
comandoed's Avatar
comandoed is on a distinguished road
Default Is this fuel pump any good?
2000 Blazer 2 dr.
Need to replace fuel pump. Is this pump any good?
SPECTRA PREMIUM / COOLING DEPOT Part # SP414MIncludes Fuel Pump, Sender, Float, Strainer and Fuel Reservoir
Is thiis better than Airtex? I cant afford ACDelco.
Old Jan 21, 2013 | 01:54 PM
spittybays
Guest
Posts: n/a
If your handy enough to drop the tank you can get this.........
New Original AC Delco Fuel Pump Kit MU1029 MU1733 | eBay
And do this.........
http://www.fullthrottlev6.com/forums...Helpfull-Hints
Then you will not have a crappy spectra that you need to change in six months.
Old Jan 21, 2013 | 02:09 PM
goredawn's Avatar
goredawn is on a distinguished road
Don't skimp here, unless you want to get used to replacing fuel pumps. After 2 my relay burnt out as well. After a few wiring harnesses and cheap pumps it gets old. I would also mention that mine were loud, even on a full tank. Get some dylectric grease and some petrolium gel handy.
Old Jan 21, 2013 | 08:34 PM
4x4blazerguy's Avatar
BUY AC DELCO or DELPHI pumps only unless as said you have lots of time & interest in pulling the tank & installing new pumps every few months. In Fact buy two cheap pumps so when you on the side of the road you have a spare.
Old Jan 22, 2013 | 06:08 AM
comandoed's Avatar
2000 Blazer 2 Dr.
Are this the correct part #s?
Should I go with Delphi?
Delphi FG0072
Ac Delco MU1755
Old Jan 22, 2013 | 09:13 AM
spittybays
Guest
Posts: n/a
One thing, make sure they will fit the two door, four doors have different tanks. If they use the same pump those are listed to fit the 2000.
BouncingRadical
14
Nov 27, 2015 12:30 AM
MountainMermaid
Nov 8, 2014 03:14 PM
MountainMermaid
Nov 7, 2014 04:04 AM
99s10blazer
Jun 1, 2007 09:13 AM
mytruck2
Dec 13, 2006 04:50 PM
