fuel pump/gas tank
fuel pump/gas tank
Can anyone tell me how the fuel line at the center fuel pump connector comes off. I have the tank dowm everything is ready to come off except I cannot get the line to unhook at the center pump connector. I have all the other lines disconnected.
Is it different type connector than the other clips? Do I need any tool?
Thanks
1999 S10 blazer 2 door LS auto 4.3l 4x4
Thanks
It is the same quick disconnect type connector and will release just like the others if you can get the tabs to release. I just use a small screw driver to get them loose.
If I remember right, that connector is the vapor line, (doesn't use the clip insert style), and it squeezes together using your thumb and index finger, then slide it off.
wjdjake
07-17-2011 02:06 AM
ericshaw
05-31-2011 08:50 PM
degaine_designs
08-19-2009 11:12 PM
SnowRemorse
01-04-2008 11:26 AM
