fuel pump help!!!
Old Feb 15, 2010 | 07:02 PM
masterrcs971's Avatar
masterrcs971 is on a distinguished road
Angry fuel pump help!!!
i have a 99 blazer that the fuel pump went out on it last week and put a new on it and had to rewire the new plug and to day the truck just stopped running while i was driving it and when you turn the key the pump dosentturn on for that few seconds it does try the tap the tank thing and that didnt work either is there something i missed in this thing that it could be???? plz help me if you can i am vary car savy just not this new stuff
Old Feb 15, 2010 | 07:56 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Slow down, use Capitals and Punctuation. What do you mean you rewired the plug? What kind of fuel pump is it? Have you checked fuses? Relay? Loose ground?
Old Feb 15, 2010 | 08:44 PM
95Jimmy's Avatar
95Jimmy is on a distinguished road
When I replaced the fuel pump in mine I replaced it with a Bosch fuel pump that came with a differrent connector than factory that you just plugged in if that's what you're talking about. That fuel pump lasted exactly 1 week and I only drove it twice. I replaced it with a Delphi and haven't had any problems since. Run a fuel pressure test and see if you're getting pressure @ the shrader- if not you can almost guarantee it's the pump. Is the fuel filter newer?
Old Feb 15, 2010 | 09:33 PM
i got the fuel pump from autozone. and it came with a differnt pulg on it and all the wires matched. i did check all the relays and fuses they are all fine. when you turn the key on you should hear the pump run and nothing is there a short in the pump some were. and i haven change the fuel filter yet either
Old Feb 15, 2010 | 09:43 PM
awe341's Avatar
awe341 is on a distinguished road
If you are not hearing the pump kick in then the first thing that you need to do is check that it is getting power.
Disconnect the plug and connect a volt meter to it and have someone turn the key to on. There are 4 wires, two for power to the pump and two that control the fuel gauge. I'm sorry that I don't know the colors of which is which by memory but you can find that information in any number of the hundreds of fuel pump threads here.
If you have a full 12v to the plug then you probably have a faulty new fuel pump. If you don't have 12v at the plug then your problem lies further to the front. Start by rechecking your connections to the new plug first.
In the under hood fuse box there is a fuel pump relay that will need to be checked. You can easily test if this relay is the problem by switching it out with one of the other known working relays of the same type such as the horn relay, fog lamps, ect.
If you have made it to that point without finding the issue let us know and we can continue helping to trace the problem from there.
Old Feb 15, 2010 | 11:16 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
I think the wire colors are Gray for the pump, Purple for the gauge and Black for Ground.
Old Feb 16, 2010 | 02:25 AM
This isn't your problem. Would be a good idea to change, but let's get it running first huh? You say that you purchased a fuel pump from AutoZone, there are different kinds, did you get the AC Delco, or a cheaper one? Do you have a warranty on the Fuel Pump? What I would do is guess it's nothing else besides a faulty Fuel Pump, or something with the wiring when you put it in. I think this because that was the initial problem and the new Fuel Pump fixed it for a while but now is happening again. Maybe I contradicted myself on that one lol. Sorry just got back from the bar. What made you change the Fuel Pump in the first place? Was it doing the same thing? If so, follow what 'awe341' said and check for power.
Old Feb 20, 2010 | 08:06 PM
aflowers230's Avatar
aflowers230 is on a distinguished road
Default Same problem here!
I just spent the day replaceing my fuel pump. I took it to a car wash the other day, drove a few blocks to sonic and it died. I managed to drive another block to the house and it would start no more. After replacing the pump I turned the ignition and no whirring sound and truck won't start. I replaced the relay with a different one and still nothing. I too had to replace the plug and have a feeling that is where the problem lies. I bought the pump off the web from 1Aauto.com it was cheap so I guess I got what I paid for. Anyone have any suggestions. I noticed someone said the gray wire was for the pump. Do I put my red or black tester lead on that and where to I put the other to ground it?
Old Feb 22, 2010 | 07:04 PM
well guys thanks for the help but i figured out the problem it was a lose line on a the truck side of the one of the fuel lines so its back and running once agian woohoo and hope all is well on here
and thanks for all the help on this matter
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
