is it the fuel pump, or maybe the relay?
Old Jun 16, 2011 | 12:11 PM
ryito1122334455's Avatar
ryito1122334455 is on a distinguished road
Default is it the fuel pump, or maybe the relay?
hi everyone, 97 blazer 4.3 4x4, since i got the blazer last week, ive noticed sometihng, when i turn the key to "run" position, (to see if the fuel pump turns on for 3-5 sec.) well it turns on and stays on! never seen this before
truck runs fine other than that. it will start right up and go, fuel pump is really loud, and it turns off when the key is set to off, but i know its not suppost to be on constantly when its in the run possition. help please, why is it doin this
Old Jun 16, 2011 | 01:45 PM
xgiovannix12's Avatar
Check your fuel pressure you can get the tool at your local autoparts the psi should be at 10 -13 psi then your pumps fine
Old Jun 16, 2011 | 02:25 PM
I know for sure that on the 98+, the pump does shut off after a few seconds of run time with the key in the RUN position, but the engine off. Not sure about the 96-97 trucks... If it's running ok, I'm not sure I'd worry too much about it though.
The pressure you quoted is considerably lower than these engines require. 55-60psi is the normal proper range for the CPI & SCFI engines.
Old Jun 16, 2011 | 02:37 PM
oh yea sorry your right !
Old Jun 16, 2011 | 02:47 PM
chris015's Avatar
lol you need to catch up gio! 10-13 is tbi motors.
Old Jun 16, 2011 | 02:52 PM
yap =P i wasnt thinking for a min
Old Jul 27, 2011 | 12:10 AM
wow, forgot to update from a while ago.....but my being a dummy.........it was the rear wiper motor (wiper dosent wipe) grinding....turned it off and no more noise....
Old Jul 27, 2011 | 03:50 PM
oktain's Avatar
*Moved to 2nd gen Tech*
New Member Area is for introductions only.
Tony H
Apr 16, 2014 08:36 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
USMaverick101
Nov 17, 2006 04:06 PM
