Fuel pump, or not?
Well, that's normal, but it also is a known problem on the second generation Blazer. It's so well known that GM made the fuel sender a separate part when it was originally part of the fuel pump assembly and replaced only by replacing the fuel pump.
Your gas gauge is going nuts because you utilized a used pump...
Once the resistor for the sender unit dries out from being pulled out of the tank and exposed to the atmosphere, they almost always act up.
This is a very common problem even with Blazers that are just ran low on gas all of the time.
BouncingRadical
14
11-27-2015 12:30 AM
exorotika
04-22-2012 04:18 PM
cide
11-07-2009 01:26 PM
mytruck2
12-13-2006 04:50 PM
