Fuel pump or not?
Old Aug 2, 2012 | 07:26 PM
antman94's Avatar
antman94 is on a distinguished road
Default Fuel pump or not?
I recently picked up a 2000 Chevy blazer. The truck seems to fall on its face when you go anywhere above like 1/2 or 3/4 of the way on the gas pedal. Today it threw two codes, P0171 and P0174, Lean Bank 1 and Lean Bank 2.
So I figured Id start simple and replace the fuel filter, no change. Then I cleaned the MAF sensor, no change. I looked inside the throttle body and it looks evenly black on both sides, no leaking Fuel Pressure Regulator. So now im led to the fuel pump, which was my first suspicion.
I bought a fuel pressure gauge and did some readings
-Key on when pump runs engine off - 60 psi
-Key on after pump is off - 53 psi
-Engine on - about 51 psi
Those readings don't seem too bad but is it enough to replace the pump? Thanks
Old Aug 2, 2012 | 07:56 PM
xgiovannix12's Avatar
Did you do a leak down test ?
Old Aug 2, 2012 | 08:12 PM
antman94's Avatar
NO! I forgot to do the leakdown when I was doing it all! darn!
Old Aug 2, 2012 | 09:15 PM
60psi key on, is borderline and 53psi key off, is too low. Best to check maximum output of the pump at the fuel filter. It will require modifying the fuel pressure tester so all fuel pressure and flow ends at the tester. Should be 73psi to 108psi on your 2000, and it must remain above 55psi for 10 minutes after the pump shuts off.
Old Aug 3, 2012 | 07:38 PM
antman94's Avatar
i did a leak down test today. Pump started at 53, and in 10 minutes it was 48. I changed the MAF sensor from my totaled truck and it seems to be running a little better
Old Aug 3, 2012 | 08:19 PM
Fuel pressure is too low. Key ON, engine OFF, fuel pump running: pressure must be 60psi to 66psi and must remain above 55psi for at least 10 minutes after the pump shuts off. See post #4 to check maximum pump output pressure. Post your results.
BouncingRadical
14
Nov 27, 2015 12:30 AM
exorotika
Apr 22, 2012 04:18 PM
cide
Nov 7, 2009 01:26 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
