fuel pump replace thru access panel..
Old Oct 24, 2008 | 03:57 PM
jcortes63's Avatar
jcortes63 is an unknown quantity at this point
Default fuel pump replace thru access panel..
I had an access panel in my previous chevy blazer 93 ., now I have a chevy blazer 2000 and I want to know if any body has a picture just to know exactly where I have to cut inside to get access and replace the fuel pump without taking the gas tank out...
regards
jc
Old Nov 3, 2008 | 10:42 PM
redblazer5's Avatar
redblazer5 is an unknown quantity at this point
Default RE: fuel pump replace thru access panel..
depending on how long you're going to keep it - cutting an access panel is just going to cuase leaksand rust very quickly not to mention that floor area will be weak since you'll be cutting thru the cross braces- drop the tank when it's near empty - grind the bolts off if you have too - just my .02 cents .
Old Nov 3, 2008 | 11:10 PM
Millertime21's Avatar
Millertime21 is an unknown quantity at this point
2door of 4door?
bigtone23
Mar 27, 2014 11:11 PM
comandoed
Mar 13, 2013 06:56 AM
JerryB52
Jun 15, 2011 04:52 AM
cide
Nov 7, 2009 01:26 PM
