Fuel Pump Testing
Old Oct 1, 2010 | 08:22 AM
giesekecw's Avatar
giesekecw is on a distinguished road
No, the solder doesn't melt. It's used in the socket connectors to provide a better electrical connection (fills the gap) ...much easier to get it working this way than to dismantle/replace the fuse box.
Thumping on the fuel tank to get the pump started? You might try dropping the spare tire for better access to the fuel pump connections. Then pull the connectors and spray some contact cleaner on the tank pins and plug sockets. Factory fuel tank connectors a notorious for faulty conductivity over time and are replaced via splicing during pump replacement.
Good luck!
Old Oct 1, 2010 | 11:58 AM
dobyken's Avatar
dobyken is on a distinguished road
Originally Posted by giesekecw
Good luck with your Blazer, hope the shop you're using knows what it's doing and is able to fix it for you. Just couldn't spend the kind of money the shops around here were asking for a fuel pump replacement. Really learned valuable info fixing it myself.
It's fixed....new fuel pump was installed. Although I most likely could have done it myself I had the garage do it for $580. I'm getting a little on the old side (60's) for crawling on my back. I will, however, tackle the next little job...front wheel hub. It pretty much looks the same as what was on my 1993 caddy front wheel drive.
smallblocks10
Apr 10, 2012 08:07 PM
Qmulus
Mar 21, 2010 01:02 PM
3D_Illustrator
Aug 12, 2009 03:52 PM
squawfishslayer
Sep 6, 2008 03:44 PM
fjdavid
Aug 16, 2007 07:32 AM
