funky headlight problem
Old Feb 3, 2007 | 12:47 AM
jagblazer01's Avatar
Default funky headlight problem
ok so my headlights started to act kinda crazy tonight. Problem is, when my low beams are on....only the passenger side works. When the high beams are on.....the passenger highbeam comes on and the drivers side low beam comes on...but high beam does not. Any ideas??
Old Feb 3, 2007 | 02:47 AM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: funky headlight problem
Sounds like a bad ground to me on the drivers side. Korey
Old Feb 3, 2007 | 12:00 PM
BlazerMan85's Avatar
BlazerMan85 is an unknown quantity at this point
Check the wiring harness/grounds. Mine does that, if I jump out and jiggle the harness it comes back on.
Old Feb 3, 2007 | 04:11 PM
but if its a bad ground why would the lowbeam come on when i turn on the highbeam?
Old Feb 3, 2007 | 06:47 PM
drperry's Avatar
Check the fuses and relays for the lights, sometimes a burnt fuse can set off that problem...
Old Feb 3, 2007 | 08:00 PM
20Blazer00's Avatar
Looking at your profile photo it looks like these are not factory lights you are dealing with. Make sure all the grounds, wires and connections are tight. If you have the factory lights put them back in and that will tell you if it really is a wiring issue or a aftermarket headlight issue...
Old Feb 3, 2007 | 08:28 PM
drperry's Avatar
The actual wiring has nothing to do with the housings, with the possible exception of the halo...
The bulbs don't use the housing as a ground or anything like that...
The lights will work perfectly fine just dangling in the air, if the wiring is in good shape...
I'm pretty sure it's a fuse or relay issue, though, but it wouldn't hurt to go out and wiggle the wires on the back of the bulb and see what happens...
What's the wattage rating on the projector bulbs?
Old Feb 4, 2007 | 12:15 PM
Kordog's Avatar
The low beam coming on when the high beams are could be because the ground is bad and it is finding a ground through the low beam bulb. I have seen this happen allot of times,grounds are very important things, that is for sure. Korey.
rodeofan5656
Jan 19, 2013 10:44 PM
acton
Sep 24, 2009 08:33 PM
rocket_rn25
Nov 17, 2007 10:20 AM
BlazerMike
Apr 2, 2007 07:12 PM
shawnese
Aug 28, 2005 11:09 PM
