TRUCK IS RUNNING FUNKY
Old Aug 25, 2005 | 09:22 PM
shawnese's Avatar
shawnese is an unknown quantity at this point
Default TRUCK IS RUNNING FUNKY
I have a 1995 chevy Blazer and it will not run. I just put a spider(fuel injectors), fuel pump, gas tank, fuel filter,distributor, spark plugs, wires, and a starter. When I crank the car up it back fires and sputters.and after around 10-15 minutes it just dies.The truck does nothing it says nothing just diesPLEASE HELP ME!!! iI AM AT MY END WITH THIS TRUCK. I LOVE MY TRUCK.I AM A WOMAN AND KNOW NOTHING ABOUT CARS. I read that it could be my EGR valve. If you know anything or just have some advice please tell me.
Old Aug 25, 2005 | 10:13 PM
blazin97's Avatar
blazin97 is on a distinguished road
Default RE: TRUCK IS RUNNING FUNKY
could be your timing.
Old Aug 26, 2005 | 11:52 AM
gmyoyo's Avatar
gmyoyo is an unknown quantity at this point
Check out our thread right around this one about EGR valve. Symptoms are very similar. Maybe worth looking at. A word of caution, AZ fetches 150 for the part with replacement warranty, but my clogged right back up so I'm looking into the reason for carbon build-up on inside my engine. Did you do your other work? Was that work done for this problem or did it start occuring after??
Old Aug 28, 2005 | 11:09 PM
Phatboy's Avatar
Phatboy is an unknown quantity at this point
Have someone look at your distributor main shaft "pole peice" The magnet on the top used for the pick up coil could be cracked. It is hard to see but you can see a hairline crack in it if you look close. This wll make your engine not want to start and if it does, it will run poorly and stall.
Let me know if this helps.
bobby099
Dec 22, 2018 09:41 PM
bigdaddykane93
Jan 27, 2016 11:35 PM
rodeofan5656
Jan 19, 2013 10:44 PM
acton
Sep 24, 2009 08:33 PM
jagblazer01
Feb 4, 2007 12:15 PM
