gas gauge >:|
gas gauge >:|
Well since I bought my loved blazer the gas gauge hasn't worked. It would either be on full or empty. Recently I've noticed it has been fluctuating around, and right now I think the gauge has actually been working. I put fuel injector cleaner in a few weeks ago. I'm nkt sure if that has anything to do with it. I think its a wiring problem but I know blazer have this as a common problem. Any thoughts as to what it could be?
Strictly coincidence, they are not related. As mentioned, the fuel level sender is probably on its way out. If you unplug the module connector, the dash gage should indicate past full. If you ground the purple wire in the harness connector, the dash gage should indicate below empty. The level sender can be serviced separately but requires removal of the tank and fuel pump module. At 108K, if you drop the tank, you might as well replace the entire module. AC Delco or Delphi only
I'm seeming to have the same issues with my blazer , but not the whole full or empty issues just the fluctuation . I fill up and drive under 20miles and it will be at a quarter of a tank if not a little less. The pump was just changed under a 2 months ago , and im guessing the sending unit was also replaced ? Can't seem to find any real info as to what tank size our 4dr's have I get 14-18 not really sure what to believe, just know that at every fill up I dont fill up past 14 gallons .
Chi_Town
Chi_Town
Chi_Town
Chi_Town
grayman63
07-17-2013 01:56 PM
98blazerb
06-20-2012 09:53 PM
starandrose
09-22-2010 06:25 PM
Mulisha
03-24-2008 09:14 PM
