gas gauge
has anyone heard of problems with the gas gauge. my gauge jumps around and doesn't give me an accurate reading of where it is ever. i have a 2000
i have the same problem and mine is a 2001
Mine bounces around once I go under 1/2 a tank. My fuel pump is only 2 years old as well and it's always been doing it before I swapped out the pump.
TONS of problems as a quick search would indicate. You can change just the sending unit, but you have to do the same steps as if you were replacing the fuel pump.
As I have suggested in many past threads, the first thing to try is a double dose of the 20gallon Chevron Techron Fuel System Treatment Plus in your next tank of fuel. It has a filming agent that is supposed to clean and protect the fuel level sending unit.
i have a 2005 Trailblazer and the gauge is now stuck on empty and the low fuel light stay's on. Do you think this will work for that also.
Same applies, but I would look over all of the wiring first to make sure that something isn't disconnected first. If you want to diagnose further, please create your own thread in the GMT360/370 section so as not to pull this thread off the original poster's problem.
grayman63
07-17-2013 01:56 PM
98blazerb
06-20-2012 09:53 PM
starandrose
09-22-2010 06:25 PM
Mulisha
03-24-2008 09:14 PM
