Gas gauge reading wrong
Just a quick question, my gas gauge reads half and then barely goes down and all of a sudden it's goes to empty... This isn't a sign that the fuel pump is going out is it?
my guess would be sending unit. but on most 2nd gen trucks the sending unit & pump is one assembly and you have to replace the entire part. i've also heard that an unaccurate gas gauge can mean a slowly dieing fuel pump. one or the other but like i said if you gotta replace both of them because they're one part you're killing 2 birds with 1 stone.
I recently bought a 2002 ZR2 with the same problem so I used the same fix we use on the Corvettes that misread the sensors. Get some Chevron Techron Plus and start pouring a can in with each fill up for about 3 to 4 fill ups and the problem usually resolves itself. It fixed my ZR2 in 3 fill ups.
You have to use the Techron Plus occasionally after that to keep the sensors clean. Good Luck.
From the fuel level sending units that I have seen, an eraser won't do much to help them read correctly. All of the ones that I have seen that were bad had the "fingers" (contacts that swipe up and down on the rheostat grid) broken off of them.
As far as whether that is a sign that the pump is about to go, that is pretty hit or miss.
blazerxtreem
Jul 12, 2013 08:06 PM
bostonblazer22
Mar 21, 2012 06:53 AM
83GMC-JIMMY
Oct 6, 2010 09:06 AM
rhaig
Nov 22, 2009 07:28 PM
