Ground Points for 2005 Blazer
Old May 15, 2023 | 10:09 PM
gojimmygo111's Avatar
gojimmygo111 is on a distinguished road
Default Ground Points for 2005 Blazer
Good evening.
I am having abs and brake light issues on my 2005 blazer. The warning lights started to appear on the dash without any noticeable brake problems. The lights disappeared after turning off the key and restarting. I am concerned for safety reasons. Due to the enormous rust on my truck and the relatively low millege (125000km), I was thinking of starting on making sure all the ground points are clean. That's from what I read here. Next will be the ECM. If anyone could help me locate all of the ground points that may affect the abs ect... I would appreciate it. How many there are, where they are located and tips to clean them up. Pictures would be gold. Thank you to all that reply.
Old May 16, 2023 | 07:31 AM
LesMyer's Avatar
That sounds most likely to be a bad solder joint on the board inside the ABS module - a common problem. They are pretty pricey new, so so may want to consider:
1. re-flowing the specific solder joints yourself (what I did). IIRC there are 4 or 6 specific places that fail. You need to use a super low watt soldering iron.
2. paying a service to do it for you
3. buying a used one
Old May 16, 2023 | 07:49 AM
LesMyer's Avatar
Old May 30, 2023 | 04:59 PM
Thank you Les. That's awesome information. I don't know how I missed your reply. I will look into this repair. The problem has been coming and going. I think I read somewhere that shutting off the truck resets the computer fault?. The shocks are not the best and I feel every bump. I can see how the soldered points on the board can vibrate themselves to the point of loosen up. Great video.
Old May 30, 2023 | 06:33 PM
reway's Avatar
reway is on a distinguished road
+1 on this repair. I had the same issue with the brake and ABS light coming on intermittently over bumps with no other issues, I took the module out and resoldered the joints and haven't had any more problems since.
eljorgin
May 21, 2019 10:04 PM
BlazerFitz
Sep 8, 2018 05:56 PM
moosehauler05'blaz
May 7, 2016 09:45 PM
hitmanK47
Dec 3, 2011 04:33 PM
Dano01
Dec 12, 2010 04:35 PM
