Hard initial start then starts and runs good
Old Dec 2, 2017 | 03:04 PM
Vintage's Avatar
Vintage is on a distinguished road
Default Hard initial start then starts and runs good
Hi hoping for help.. 96 Blazer I do not have a fuel pressure tester so i took this to a shop i use. This just seems a little unusual because after i get it to start it then starts fine for up to 4 hours or more. Runs good no drive ability problems or codes.. Shop has it sitting with gage connected to see what the pressure is after the weekend. Wondering if it is fuel pressure or something else. I would like to correctly diagnose before replacing the fuel injectors which the shop feels is what is wrong.
Any thoughts are appreciated. Fuel or something else that should be tested ?
Thank you
Old Dec 2, 2017 | 04:36 PM
AJBert's Avatar
Have you tested the battery yet?
Old Dec 2, 2017 | 04:57 PM
GreenBlazer2002's Avatar
I had that same issue. Upgraded injectors cured it.
Old Dec 2, 2017 | 07:19 PM
Vintage's Avatar
Thanks for replying i will check battery , good to know about injectors, i think i have what they call spider injection which according to the shop had problems.
Old Dec 2, 2017 | 11:35 PM
GeorgeLG's Avatar
The two main tests that would confirm injector problems are not holding fuel pressure per the sticky or failing the injector balance test with a pulse tool.
George
Old Dec 5, 2017 | 04:58 PM
Vintage's Avatar
Just to update members following this post. May have been caused by a small leak in the fuel line from the filter to tank. Will update later whether replacing the rusted line resolved the hard start problem.
Old Dec 5, 2017 | 09:47 PM
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
You're lucky. That line is around 65PSI.
Old Dec 11, 2017 | 07:30 PM
2004 Blazer's Avatar
2004 Blazer is on a distinguished road
That is a powerful message right there !
Old Dec 18, 2017 | 04:13 PM
ouwee's Avatar
ouwee is on a distinguished road
Question Puzzled
My Blazer is a 2001. When I go to start it, it spins like maybe it's not getting fuel. After a few tries if will crank up and it runs fine. Can anyone tell me what I need to do to solve this issue please?
Old Dec 18, 2017 | 10:43 PM
Best place to start is with a fuel pressure test. See this:
Part 1 -Troubleshooting the Fuel Pump (GM 4.3L, 5.0L, 5.7L)
