Hard initial start then starts and runs good
Old Dec 22, 2017 | 11:04 AM
  #21
ouwee's Avatar
ouwee is on a distinguished road
Hi George,
Can you send me a link to a video so I can watch how to do this test, please sir?
Old Dec 22, 2017 | 11:38 AM
  #22
GeorgeLG's Avatar
This is a related engine and should get you close:
Also you can read the sticky at the top of this forum. Another poster talks of a cost effective Harbour Freight universal pressure gauge for testing.
George
Old Dec 27, 2017 | 02:27 PM
  #23
02Blazerboy's Avatar
02Blazerboy is on a distinguished road
Question Crank an. Crank vapor lock crank n start
I am a bit puzzled new dizzy, cap, an rotor started getting cold started having more problems starting thinking it needs a new battery as of right now anything else I should look into be for a new battery ?
Old Dec 27, 2017 | 04:04 PM
  #24
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
Whenever I replace a blazer battery I get a 78 series because they are the largest that will fit the battery tray and have more power. I also search around for a dual post with both side and top terminal. makes jumping to or from a lot easier.
Last 2 I bought were this one. Made a huge difference in how my plow truck recovers from a lot of lifting and turning the plow:
https://www.menards.com/main/tools-h...7428956&ipos=6
Old Dec 27, 2017 | 06:16 PM
  #25
GeorgeLG's Avatar
The proper way to test a battery is a load test. You do a full charge, bleed off the surface charge with a short headlight cycle then load the battery to spec and see what the voltage is. Most battery shops can do this for you or you can buy a load tester which is either a carbon pile resistor or wire coil pack in a metal box with a meter and jumper cables.
George
Old Dec 27, 2017 | 08:17 PM
  #26
Snap-Off's Avatar
Snap-Off is on a distinguished road
I got one of those metal box battery load testers with the coil from O'Reilly Auto for $45...Had to use it on 3 different cars the first month I had it. Works pretty well.
LazyM
Aug 31, 2016 04:12 PM
ernestiv
Apr 18, 2015 03:02 PM
barnesto
31
Jun 11, 2014 07:12 PM
reddheadnla
Apr 23, 2011 11:08 AM
ryanmancl
Jul 2, 2010 04:44 PM
