Has anyone bought a remanufactured Spider injector assembly from rockauto before?
#41
okay....someone please tell me the nomenclature, a part number, and a place to get this 'fuel line nut kit'.....
I replaced the FPR. It was leaking. I also replaced the UIM gasket, TB gasket, got a new MAP, etc.
I essentially have the same fuel pressure readings as above, yet I have a hard cold start after it sits for several hours. It can take 6,7, or more tries to get it going. I have virtually no driveability problems. It does seem like its not getting enough fuel....
I think it might be leaking because I see some sites cleaner than they should be.... I have a kit for tearing into the spider and cleaning that up (new o-rings and stuff). Are the rings I need for the fuel line in there...? This kit (fel-pro) didn't have instructions....
I have the part number at home and can share it later....
Thanks....
Thanks....
#42
get the parts at www.rockauto.com
the dorman brand is 36 bucks and the Delphi brand is 48 bucks...
what year truck you working on?
#43
I have Dorman Part # 90000 - fuel injector and seal cover kit.
contents:
20 o-rings
10 retainers
2 nuts
2 plates
2 washers....
Does this work...? I got it a few months ago from Advance and haven't tore back into things again to put these in.....
contents:
20 o-rings
10 retainers
2 nuts
2 plates
2 washers....
#44
No, it is not. That indicates that you have a leak somewhere in the system.
The 96+ Fuel Pressure test procedure will give you some more pointers even though yours is a 95. The CPI motors have the same fuel pressure requirements as the SCFI motors. They both have the same pressure actuated poppet nozzle design at the intake runner.
ChevOeat
14
11-21-2011 01:33 PM
JeffUSMC
01-16-2010 12:53 PM
