Has anyone experienced this?
Old Jan 7, 2007 | 11:11 PM
Gunner Woody's Avatar
Gunner Woody is an unknown quantity at this point
Default Has anyone experienced this?
When I am driving my 99' S-10 Blazer LS there is a "poping" noise comming from the front end when I deaccelerate and turn at slow speeds (especially when I back out of my driveway and am turning). I have changed half-shafts on both sides and have had the lower bushings replaced (mechanic said the uppers were fine for another year). The hub on the passenger side was changed a year ago and the driver side is still good. This is starting to get expensive with all of the other upkeep on my 3 other vehicals. Any ideas?
Old Jan 7, 2007 | 11:45 PM
hillbillyinOhio's Avatar
Default RE: Has anyone experienced this?
my guess would be ball joints.
Old Jan 8, 2007 | 01:40 AM
Russyo's Avatar
Russyo is an unknown quantity at this point
i would agree with ball joints, and maybe a sub frame shift, tighten everything down and see what happens. Also check to see if you spring is seated well it the shock assembly. My cobra used to pop when i braked or accelerated hard, and it was the spring not sitting straight in its pocket. Good luck.
Old Jan 8, 2007 | 03:39 AM
Chevy Lover's Avatar
Loose caliper bolts?
Worn ball joints?
Broken link pin on the swaybar?
Worn c/v joint?
Old Jan 8, 2007 | 09:42 AM
My vote would be for balljoints as well. As a temporary check, try greasing the front end and see if the noise goes away. If it does, then you've got a problem in one of the joints that you greased. If you really wanted to narrow it down, grease one thing at a time and go for a drive.
chevylover5
Dec 24, 2013 08:31 AM
altoncustomtech
Jun 16, 2011 08:14 PM
XxJimmy.86. DieselxX
Jan 4, 2010 09:00 PM
kankoon52
Dec 7, 2007 03:36 PM
vagnozzi
Apr 27, 2007 09:15 PM
