passenger side window problem
Old Jan 6, 2007 | 06:36 PM
bowanna03's Avatar
bowanna03 is an unknown quantity at this point
Default passenger side window problem
I have a 1998 gmc jimmy my passenger side window works from its own switch but it will not work from the drivers side switch but all the other windows open from the main switch
Old Jan 6, 2007 | 09:04 PM
DINO55's Avatar
DINO55 is an unknown quantity at this point
Default RE: passenger side window problem
Could be dirty but more then likely youhave a bad master window switch, Have you checked the plugs on the bottom of the master switch to see if any wire's may have come loose? How abouta voltage check on it?
Remember every time it's rainning outside and you open up your drivers door, a lil rain get's inside those switches...
Old Jan 6, 2007 | 11:37 PM
Chevy Lover's Avatar
Yup, Like DINO55 said, that's how I would have suggested
Old Jan 7, 2007 | 08:07 PM
bowanna03's Avatar
i checked the connections and they were all on ok i dont know much about checking for voltage ho wwould i do that
Old Jan 7, 2007 | 08:09 PM
woodsballr's Avatar
woodsballr is an unknown quantity at this point
get a volt meter and compare its readings with what the manual says you should get
Old Jan 8, 2007 | 10:40 AM
rooster's Avatar
rooster is an unknown quantity at this point
the master switch for the windows can be found in the help section of any auto store. these are very common to go, so they should have them. 99% of the time it really is just a bad switch. which run about 50 bucks, so i would pick it up as well as a voltometer(probably will come in handy later in life).
Old Jan 8, 2007 | 11:23 AM
bowanna03's Avatar
thanks guys ill try that
upmaine
Jul 9, 2012 12:31 PM
408blazer
Jun 9, 2012 11:04 PM
roae22
Mar 22, 2010 11:35 PM
burt
Sep 2, 2008 02:15 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
