Having a hard time...
#21
Abs on scantool
My scan tool says ABS on it but then it says ABS is not supported for this vehicle. I know I need to update the software I don't know if it can activate the ABS or not I need to see about downloading updated software .
#22
All right I'll get to it now I can access the old calipers I still do have those I will reinstall at least one maybe both take it out for a drive and see what happens and go from there.. thanks for your time and your direction GeorgeLG. I'LL GET BACK TO YOU AS SOON AS POSSIBLE
#23
George
#25
George
#26
If you want to compare calipers do it cold. Mount the old one, pump everything up with the MC mounted properly, release the hydraulic pressure at the caliper and then see how much it grabs and how much noise it makes. The new pads complicate this somewhat because they are not yet seated 100% level and smooth like the old ones.
I will reiterate, the best approach is to partition the brake circuit into sections, test each area and then go further when you find a fault. Do a targeted repair and then verify. Stabbing at it and swapping parts can introduce new problems where there were no problems because of inferior non AC Delco parts or install issues and/or you might waste time and money. You have a verified problem, get that fixed and you are becoming a first rate auto mechanic.
George
George
#27
George
#29
Ive had to take a short reprieve and go out of town briefly but I will get back at it tonight. But to answer your question yes if I pump the brakes when the engine is at idle it does mess with my idle rpms
#30
We know we have a problem at the firewall and now we know we probably have a vacuum problem during braking so the boost may be involved. You can start by watching this:
You can verify that braking is causing a vacuum leak by watching fuel trims or a vacuum gauge during braking.
George
George
madblazerowner
19
03-02-2012 12:43 PM
