which headlight bulbs for 96
Old Jan 29, 2006 | 09:49 PM
dropd4door's Avatar
dropd4door is an unknown quantity at this point
Default which headlight bulbs for 96
before i go to the store which bulbs are for the daytime lights, high beams, low beams... i tried looking online but it said about 10 different bulbs... which are for what ###owned a blazer for 2 days### lol
Old Jan 30, 2006 | 02:45 AM
LoLoS10Blazer87's Avatar
LoLoS10Blazer87 is an unknown quantity at this point
Default RE: which headlight bulbs for 96
I'll answer your question, but you'd definitely get more help if you posted this in the General Tech Help section.
Assuming that you have a composite system, your high beam will be a 9005 and your low beam will be a 9006.
Need more info? http://www.autozone.com <---Clicky
Old Jan 30, 2006 | 09:19 AM
dropd4door's Avatar
what about daytime bulb? and thanks
Old Jan 30, 2006 | 11:33 AM
The Daytime running lights use the high beams at either a lower supply voltage or a lower supply amperage (can't remember off the top of my head right now). But anyway, there isn't an additional DRL bulb.
*EDIT* - will move to the General Tech Help section.
Old Jan 30, 2006 | 06:00 PM
smplgrn's Avatar
smplgrn is an unknown quantity at this point
On my 96 it uses 1 buld for high, low, daytime running lamps
Old Jan 30, 2006 | 06:18 PM
Yes, there are some blazers with a dual filament bulb that runs both high, low, and DRLs. The housings are generally larger.
jonesjamesw
Mar 16, 2008 06:54 PM
2002XTREME
Jan 22, 2008 10:38 AM
bpmadsx
May 25, 2007 09:48 PM
EuroGoldLS
Apr 14, 2007 08:24 AM
blazinloud
Jan 6, 2007 03:55 PM
