Headlight high beams and low beams on together. Need a fix
I have HIDs and one of them recently burned out so the new bulbs are on order but I noticed today that the one low beam I have left is on but the high beams are on as well but the indicator light for the brights is not illuminated on the cluster. Any ideas???
Thanks,
Dan
Thanks,
Dan
If this fuse blows, not only will you not have park lamps, but the headlights will not work correctly either. As a matter of fact, if this fuse is blown you will only have one light on in dim, and ALL lights come on in bright.
wow i feel like a moron. right after i posted this i thought id check the fuse just in case becuase i was covinced that wasnt it for whatever reason and what do ya know?! its the fuse.
I just removed the HID kit from my Blazer today and replaced it with all regular bulbs (brand new) highs and lows. Same problem as before but all of the fuses look good. Any help is always appreciated
dflanigan
01-03-2014 06:06 PM
cory30189
12-25-2012 08:12 PM
putting tranny together, lost the spot i was in, now i dont know how it goes back together!!!!!!!!!!
rob1621
03-09-2008 09:39 AM
