headlight removal *repsond ASAP*
Old May 26, 2008 | 05:53 PM
RidnClean's Avatar
RidnClean is an unknown quantity at this point
Default headlight removal *repsond ASAP*
im trying to remove the whole headlight housing so i can tint them
but im having trouble find all the spots
help please?
PS: ive searched everywhere
Old May 26, 2008 | 07:15 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default RE: headlight removal *repsond ASAP*
http://www.autozone.com/shopping/rep...00c152800bff5dthat should be it. Make sure your state allows headlight tinting, I know mine doesn't.
Old May 26, 2008 | 07:16 PM
Tinting your headlights...?? Doesn't that defeat the purpose?
Is this info in the owners manual??
Anyway, there will be two black tabs to the back side of the radiator support directly behind the headlight. Pull up on them and then remove the headlight.
Old May 26, 2008 | 07:23 PM
portcqb's Avatar
Yah it should be in manual also if you have one handy autozone was easier to access than gmlink.
Old Jun 9, 2008 | 09:12 PM
cbright890's Avatar
cbright890 is an unknown quantity at this point
yeah, there are two tabs right behind the headlights, just pull them up and the headlight should come right out. in my case for some reason i had to remove the entire grille to put the hadlights bck in properly, if u need to remeve the grille, just tug on it and te clips should just pop right out of the holes in the frame. be sure to tug gently or you may crack the grille.
johnjfeher
Mar 18, 2015 12:08 PM
musclecar70sfan
Aug 15, 2010 06:45 PM
oktain
Jan 14, 2010 06:31 AM
Psychropod
21
Jan 29, 2008 02:37 AM
Ranger Rick
13
Apr 24, 2005 02:50 AM
