headlight removal *repsond ASAP*
http://www.autozone.com/shopping/rep...00c152800bff5dthat should be it. Make sure your state allows headlight tinting, I know mine doesn't.
Tinting your headlights...?? Doesn't that defeat the purpose?
Is this info in the owners manual??
Anyway, there will be two black tabs to the back side of the radiator support directly behind the headlight. Pull up on them and then remove the headlight.
yeah, there are two tabs right behind the headlights, just pull them up and the headlight should come right out. in my case for some reason i had to remove the entire grille to put the hadlights bck in properly, if u need to remeve the grille, just tug on it and te clips should just pop right out of the holes in the frame. be sure to tug gently or you may crack the grille.
musclecar70sfan
Aug 15, 2010 06:45 PM
Psychropod
21
Jan 29, 2008 02:37 AM
