hear loud pop, antifreeze all over engine
Old Mar 10, 2017 | 12:03 PM
stevenbruce's Avatar
stevenbruce is on a distinguished road
Default hear loud pop, antifreeze all over engine
Have a Blazer 2000 6 liter, shut off the car. couple minutes later hear loud pop.stream was coming from under hood. Pop the hood, look like the coolant was spray from back of engine to the front. was some coolant on battery. look under car seems to be dripping in the back of engine? Any ideas what I should look for. any help will help thanks.
Old Mar 10, 2017 | 12:12 PM
chris015's Avatar
just pour water into radiator,and look for where ever it starts puking.
Old Mar 10, 2017 | 02:22 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
You can put a pressure tester on the radiator as well to help find the leak.
Old Mar 12, 2017 | 04:10 PM
dman001948's Avatar
dman001948 is an unknown quantity at this point
In my opinion: Not good. I don't think your radiator is located in the back of the engine. Maybe a freeze plug blew, the only other thing I can think of is a head casket that blew in the rear of one of the heads...Good luck...
Old Mar 12, 2017 | 04:19 PM
CWBDDSPC's Avatar
Sounds more like a hose to me...
Old Mar 13, 2017 | 07:28 AM
LesMyer's Avatar
This (above)! Look at the hoses (radiator hoses + heater hoses). Easy fix unless you got the engine too hot and that is what blew a hose. If engine is OK, probably time to replace all the radiator, heater, and water pump bypass hoses. Are they soft and swollen at the clamps?
Old Mar 13, 2017 | 03:19 PM
Tajohns34's Avatar
It could easily be leaking from the front and running down the frame and dripping by the rear of the engine.
bigzimnh1
Jan 20, 2013 08:14 PM
Chevy33
Nov 25, 2010 11:47 PM
rocketman14
Jul 8, 2008 09:04 AM
knuckles
May 22, 2006 02:11 AM
Rwolf
Feb 13, 2006 01:46 AM
