Heat/AC only blows through defrost
Old Aug 10, 2009 | 03:08 PM
taloka's Avatar
taloka is on a distinguished road
Default Heat/AC only blows through defrost
I have a 96 Blazer and the heat and A/C only blow through the windshield defrost vent no matter what position the heat/air switch is in. Someone told me it was a vacuum line problem but I don't know. I didn't know if there is a door somewhere that is not switching properly. Just need an idea as to where to start looking.
Thanks.
Old Aug 12, 2009 | 03:35 PM
Rhodes19's Avatar
Rhodes19 is on a distinguished road
Most likely it is a vacuum problem. I just fixed a similar problem with my oldest daughter's Jeep. Now I will be doing some ac work on my youngest daughter's blazer. You should be able to follow the vacuum line from the engine, through the firewall, and to the mode selctor switch (ac, defrost, heat switch). It will be easiest to check the vacuum line in the engine compartment first and if its ok. Go to the mode selector switch next and see if you are getting any vacuum there. If you do get a vacuum to the switch then you may have a bad switch. If there is no vacuum at the switch then you will have to trace the vacuum line to the firewall. HTH
Old Aug 13, 2009 | 03:58 PM
taloka's Avatar
Thanks for the info. I didn't realize that the vacuum line had anything to do with the switch. I had heard that but not being much of a mechanic I didn't know. Thanks again.
Old Aug 14, 2009 | 12:02 AM
mchap87's Avatar
mchap87 is on a distinguished road
i had the same problem with my 95 blazer. It turned out to be the vac line at the back of the upper manifold was unplugged. It was a easy fix for once.
Old Aug 16, 2009 | 11:07 PM
stapler2025's Avatar
stapler2025 is on a distinguished road
Had this same problem on my '96, just fixed it today.
The vacuum line was actually rubbing against the manifold, and had scorched a hole thru the tubing, not to mention all the vacuum lines are shot anyway.. Now they're all replaced and it works tons better
Yay for ventilation again
Old Aug 17, 2009 | 03:12 AM
jcws6's Avatar
jcws6 is an unknown quantity at this point
More Info:
If it's a "door" problem, the air generally doesn't blow through the defrost on all settings. When I had a problem with my air door, it was only on the "floor" setting. There are 3 "zones" for air output: upper (defrost), central (main vents), and lower (floor). If all "zones" are affected, it's generally a vaccuum which affects all of them. Defrost is the failsafe - it opens so the air goes somewhere, even if the system doesn't work.
dunontme
Sep 22, 2008 09:49 AM
peanutblaze
Feb 17, 2008 06:07 PM
peanutblaze
Feb 11, 2008 09:15 AM
rdhack
Feb 9, 2008 10:32 PM
kammino
Nov 27, 2006 11:35 PM
