Heat can't get right!!!!!!
Old Dec 28, 2008 | 02:24 PM
str8216's Avatar
str8216 is an unknown quantity at this point
Default Heat can't get right!!!!!!
98 blazer 4wd 4x4
I have heat working very well when the vehicle is first turned on and after about 5-10 secondsit sounds like a door closes and stops the heat from coming through. In defrost it will continue with heat but it has to be on high although it blows with little pressure. In the front vents it just completely goes out and blows cool air but the pressure does not change like the defrost. The feet air is the same as the defrost.I have had every possible flush, thermostat changed, and vaccum is alright under the hood. I live in ohio and its pretty chilly without heat. I am trying my best to stay away froma shop soall assistance isgreatly appreciated.Can someone PLEASE HELP ME!!!!
Old Dec 28, 2008 | 02:39 PM
str8216's Avatar
Default RE: Heat can't get right!!!!!!
I meant 98 blazer 4dr 4x4
Old Dec 28, 2008 | 03:00 PM
mrafindley's Avatar
mrafindley is an unknown quantity at this point
I have same problem on a 97
Old Dec 28, 2008 | 07:58 PM
Default RE: Heat cant get right!!!!!!
For both a 97 and a 98, the air temp door is an electronic actuator.
Here are the vacuum logic and a diagram of the system for a 98:
The system schematics are the same between the 98 and the 97:
And the problems being described by the OP seem to be a bit different than yours Anthony as your truck takes ~10 minutes to have a diminished HVAC airflow output while the OPs takes 5-10 seconds.
A-Rak
Jun 22, 2011 10:36 AM
EMSEE
Mar 15, 2011 11:49 AM
90K5Blazer
Oct 7, 2009 10:01 PM
z
Jan 19, 2008 01:14 PM
pigmak
Nov 26, 2006 06:02 PM
