Heater blend door actuator change
Old Nov 13, 2012 | 02:07 AM
sacrosuchus's Avatar
sacrosuchus is on a distinguished road
Default Heater blend door actuator change
Hi!
First ... i am from germany and my english is not the best, please sorry for that.
I have a 1999 Chevy Blazer and out of the air System it cames all the time hot air. From the glovebox it cames a "sssst clack" in time intervals, so i think the heater blend doort actuator ist damaged.
After some search i found a removal instruction, follow it (with some curses and bloody finger), but after i screwd out the two front screws, the actuator will not lift of from its place.
I thought there was one more screw and this one i could not reach. So i stop my attempt and give up.
But now i read in an english forum there is no third screw... but how hangs it, or my right question: How i detach this actuator?
Greetings from Germany to all Chevy Fans...
Frederic
Old Nov 13, 2012 | 09:54 PM
99blzr's Avatar
99blzr is on a distinguished road
There are 3 screws that must be removed
Old Nov 14, 2012 | 05:08 AM
Hi!
Ok, but who unscrew the third screw? I can see it, and over this screw is only a little room.
Greetings...
Old Nov 14, 2012 | 12:21 PM
50lb_cat's Avatar
https://blazerforum.com/forum/tech-a...-method-69608/
Did you follow this link? There are only 2 screws, after that it should lift up and out of the bracket. It might be stuck in there pretty tight.
Old Nov 15, 2012 | 03:59 AM
Hi!
Yes yes... i found this link and use ist as instruction manual.
I came until remove of the screw, but the actuator seems to hang on the back side.
And 99blzr says "There are 3 screws that must be removed"....
I am confused!
Greetings...
Kidkaos70
Apr 20, 2011 11:35 PM
ravenhurst
Feb 16, 2010 05:53 PM
stickemdano
Nov 14, 2009 11:13 AM
markrd
May 8, 2009 01:39 PM
