Heater Core Casing Gasket
Old Dec 22, 2010 | 11:06 PM
Cyberlight's Avatar
Cyberlight is on a distinguished road
Today I removed my leaking heater core, and discovered that both halves of the housing, as well as the heater core itself are installed with some form of gasket. It looks as if it was squirted in the groves then the housing closed, forming a gasket. This was in pretty bad shape and also soaked with coolant. My question is, can I re-create this with black RTV, and apply it, wait for it to skin over, then compress it so it forms to the cavity but not bond? Any advice would be appreciated. Thanks.
By the way, thanks to everyone for all the writeups on how to do this swap. I have a 97, so it was slightly different, but still manageable.
Last edited by swartlkk; Dec 23, 2010 at 07:54 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Dec 22, 2010 | 11:34 PM
rwd681's Avatar
rwd681 is on a distinguished road
swapped my heater core last weekend so I know exactly what you are talking about. The RTV helps direct airflow through the core. you can use rtv or foam window sealant from the local home improvement store. I used just a dab of rtv and everything turned out fine.
Old Dec 23, 2010 | 07:59 AM
It likely was caulking that was used. You can pick up some butyl tape to recreate the factory seal. RTV works as well, but may be more difficult to clean up unless you spread it nice and even and let it setup.
limited edition 1
Jan 27, 2023 11:07 AM
mylittletonkatruck
Mar 7, 2012 02:04 PM
J.R. Clay
Mar 17, 2011 08:22 PM
LJ809
Apr 25, 2010 06:02 AM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
