heater doesn't blow on high
Old Jan 21, 2005 | 05:45 PM
jimmyone's Avatar
jimmyone is an unknown quantity at this point
Default heater doesn't blow on high
I need some help with my 98 blazer,
the heater blows but not on high, it just stops blowing.
I checked the two wire at the blower motor and there is juice when on the lowest speed settings but when turned to the highest blower speed the juice stops.
Thanks
Old Jan 22, 2005 | 12:59 PM
blazzinblazer1998's Avatar
blazzinblazer1998 is an unknown quantity at this point
Default RE: heater doesn't blow on high
A few months ago my heat/ac started making some loud noises. So I had it taken in and it seemed to be the heater coil and blower motor. After I got it back, I didnt notice initially, but high did not work. So its back in the shop now and they are saying its the blower motor relay. Not sure if this will help, but its worth a shot.
Old Jan 24, 2005 | 01:34 AM
jimmyone's Avatar
Thanks, I read it might be the blower relay. Can someone help me with a location and discription of this relay?
Old Jan 27, 2005 | 06:32 PM
gzalycki's Avatar
gzalycki is an unknown quantity at this point
Having Same problem Jimmyone. I installed a new blower resistor unit, didn`t fix the problem. There must be a high speed blower relay just for the high setting. I have a 99 S10, from what Ive researched online the relay is probably under dash behind glove box. I have not confirmed this yet, as it has been around 0` here in rochester.
mrspeedy69
Apr 30, 2013 09:46 PM
bwaynef
Mar 30, 2013 08:51 PM
lazer2000
Sep 16, 2012 11:16 PM
bigred52
Oct 28, 2010 06:58 AM
Antne
Jul 7, 2009 09:47 PM
