High Beam Doesn't work
Old Dec 6, 2012 | 01:45 PM
mrspeedy69's Avatar
mrspeedy69 is an unknown quantity at this point
Default High Beam Doesn't work
I have an 02 LS 4x4 and my drivers side High beam doesn't work. I bought a new bulb and replaced it, and it still doesn't work. Tried the bulb on the passenger side and it does work there. So it's just on the drivers side.
I pulled back some of the tape and looked at the wires and the connector and everything seems to be ok. I decided to take a volt meter too it but I couldn't really tell anything. It seems to just jump around a lot. I also used the volt meter on the passenger(working) side and it just jumps around too.
Does anybody know what the reading is suppose to be at the connector, or anything else I can try to check.
Old Dec 6, 2012 | 04:50 PM
richphotos's Avatar
Clean the connections, they are probably corroded.
Old Dec 7, 2012 | 10:47 AM
mrspeedy69's Avatar
Forgot to mention I already did this.
Old Dec 8, 2012 | 02:13 AM
Thogert's Avatar
They should both be reading 12ish volts steady. Check your grounds and see if they need cleaning.
Old Dec 11, 2012 | 09:55 AM
mrspeedy69's Avatar
Are you talking about all grounds in general or is there a specific ground to check for these?
Old Dec 11, 2012 | 10:54 AM
richphotos's Avatar
Grounds for the headlights should be located on the core support hear the headlights themselves (well they are on the first gen)
Old Dec 11, 2012 | 04:15 PM
mrspeedy69's Avatar
Thanks, I'll take a look tonight and see what I can find.
Old Dec 15, 2012 | 02:33 PM
mrspeedy69's Avatar
So I checked the grounds, all fuses again, and I replaced the headlight plug and still the drivers high beam doesn't work. Traced back the wiring as far as I could and it all looks fine.
Not sure if it's related or not but my third brake light isn't working either.
Old Dec 15, 2012 | 03:45 PM
The headlamps have separate fuses for left & right. Each fuse protects the respective high and low beam filaments. If both low beams work, both fuses are OK. The purple, (high beam ground) wires exit the underhood fuse panel and run seperately to each high beam socket. The one that runs to the left high beam has an open circuit somewhere. You can do one of two things: Locate and repair the open circuit, or, run a jumper wire between the purple wires at each high beam socket. The open circuit could very well be inside the underhood fuse panel. Sounds crazy but, yes, the ground wires connect inside the fuse panel. Post your results
Old Dec 16, 2012 | 01:07 PM
rezlab's Avatar
rezlab will become famous soon enough
as Captain Hook said with the fuses or some vechiles are now coming with relays for each headlight low and high beams so its either the drivers side high beam fuse or relay. would be my guess
