Heater fan 95 Blazer
Old Jan 20, 2008 | 10:41 PM
Steroid Wagon's Avatar
Steroid Wagon is an unknown quantity at this point
Default Heater fan 95 Blazer
The heater was working for about an hour into my shift tonight, It then stopped and I had a slight smell of plastic inside. I turned off the heater controls. I tried to use it about an hour later and nothing worked. I popped my hood and checked under the disinigrating shroud to tap on the motor, nothing happened. I popped the dash face loose and wiggled wires and got no reponse there either. It was working fine on all speeds earlier. The fuse isn't blown because I got off of work early, went home to grab my meter to check for power and when I started my truck, it was working fine again. There has never been any noise, its been a quiet motor. What would cause it toshut down due to being over heated? where do I start looking?
Old Jan 20, 2008 | 11:51 PM
Chevy Lover's Avatar
Default RE: Heater fan 95 Blazer
I would remove and inspect the blower resistor. The problem may be obvious when you have it out.
gitch93
Jul 23, 2013 08:06 AM
cheesequaker
Apr 25, 2012 01:44 PM
85kulan
Oct 4, 2011 09:51 AM
valeria1782
Jan 24, 2011 04:12 AM
upblazer95
Nov 16, 2008 03:20 AM
