hellllp leaking everywhere
well had 97 blazer for one week now and im pissed off, its got coolant comeing out where the intake manifold runs on side with valve cover and leaks more when givin more gas so is that a headgasket? what should i do? its leaking and comeing right down by the starter bolt but u see it build up more water up by intake manifold or well lower intake when revved so idk wtf too do
Def sounds like intake manifold gasket is shot. Check your oil asap for cross of fluids.
mine leaked in same spots in valley along valve covers. There is a how to on the forums.
it took me 12 hours to do...was a learning exp. If you do it yourself get the felpro gaskets with a 'T' in tha parts code. Gaskets cost me 90 something.
good luck
good luck
mattbo324
Feb 2, 2013 11:50 PM
