Help on blazer fuel leak problem
Old Feb 19, 2011 | 10:13 AM
cowwgirl08's Avatar
cowwgirl08 is on a distinguished road
Default Help on blazer fuel leak problem
I am new the the forum I have a 1995 chevy blazer four door 4wd with the 4.3. I am getting a fuel leak from the fuel line above the frame rail just below the back door. Is this a common problem? Also how do i tell if it is the sending or return line?
I need to fix it soon it's my DD
Thanks for any and all help
Amber
Old Feb 19, 2011 | 11:38 AM
rriddle3's Avatar
*Moved to '2nd Gen Tech'. The 'New Member' area is only for introductions, not for technical questions.*
Old Feb 19, 2011 | 02:11 PM
The return line isn't under pressure (or shouldn't be) so if that is leaking, it would take quite a bad spot to cause a leak. It is much more probable that it is the supply line to the engine.
It isn't really a common problem, but considering that the vehicle is 16 years old, it isn't unheard of, especially in the salt states!
Old Feb 20, 2011 | 07:28 AM
old skool luvr's Avatar
regardless if it's a supply or return line, it'll require the same kind of repair.
Big Eazy
Apr 27, 2013 12:48 PM
jck1961
Jul 26, 2011 09:18 AM
abadinalbany
Jun 1, 2009 08:27 PM
TAZ454
Jan 28, 2008 10:11 AM
