help guys clicking sound
hey guys i have been looking around your great site the last few weeks an today i need some help . i did do a search before i posted but non of them sound like my problem . i just picked up a 00 2wd jimmy an all has been well untill today . me an the wife were driving down the highway at about 65 when we started to hear a clicking sound " sound like a relay or your turn signal flasher when you have them on " it sounds like is coming from the passenger side kick pannel . any of you have an idea on what it could be or a sarting point on where i can start .
when i did some looking all i could find was info on 4wd trucks having a control mod for the transfer case that makes a clicking sound .
thanks guys an gals .
justin
justin
justin
justin
I have a similar problem to this one... while I was taking a back road to the shop (a somewhat bumpy dirt road) it suddenly stopped, and it also stops whenever I press the brake pedal.. and I was then doing it intermittently on the drive home. I'm guessing some sort of short, especially since I have an aftermarket remote start system on my truck... no ideas where to start to look though
Our 1993 Blazer has the same issue. We replaced the steering column with a rebuilt one with no luck. Removed the glove box and the noise appears to be coming from the black box below the ecm unit.
When I hear a fast clicking sound all of a sudden I check my tires for rocks.
Is it consistant with speed IE: it goes up & down as you speed up or slow down?
I'd start by looking for a vacuum hose that is buggered up, weathered etc that leads to the area by or under the battery. Under there is the actuator for the 4wd. If you have a leak (& crappy gas mileage) that could be the cause.
How are the HVAC controls - everything work as it should or are things really slow or only in a vent or on foot? Or can you change them from vents to floor only or defrost easily & they respond?
It could be a pebble or something in the ABS sensor that got flung up.
Blazinflaboy
Jun 22, 2010 09:03 PM
rastoma
Mar 4, 2010 08:34 AM
GloryImSaved
Jul 16, 2009 12:50 AM
Buschkj24
May 24, 2009 09:50 PM
chevblazer02
Mar 6, 2007 04:49 PM
