Help With Knocking Sound
It's driving me nuts trying to figure out what it is.
When I start the blazer- a full 2 to 3 seconds later I hear a knocking sound. 30 seconds later it goes away. With the skid plates off and under the truck I still cannot figure out whether it's comming from the bottom or the side wall of the engine. It's not as deep or loud as a rod knock.
My mechanic said he didn't hear it when ileft it overnight for him to listen to in the morning- he must of blew me off because it is loud.
does anyone have any suggestions- the 2 to 3 full seconds after start is throwing me off.
Thanks-
Thanks-
I figured it would be heard to do over the internet.
With it starting 2 or 3 seconds after start i was hoping that may give an idea.
what's the flex plate?
Thanks
Thanks
Hey! After replying to your post,I have thought about it & all possibilities-I would go where kristoph30 went! A flexplate is the equvilant of a flywheel-used on auto trans units to smoothly transfer power,but also resiliant enough to prevent damage from starter over-engauging. This is also helpful when a wheel is slipping and suddenly gets traction-enough breakage can occur there!The flex plate will break instead! Many manufactuers offer replacements ecomically-Its the job that is costly at retail,as the trans must come out! Do not have this job done at retail! Good luck!
The name "Flex Plate" comes from the fact that it intentionally flexes as the torque converted expands and contracts for changing RPMs and fluid pressures.
It NOT designed to break for any purpose. It can fail if it is damaged, poorly designed or poorly manufactured like any other part.
A cracked flex plate typically will not go away.
A sticky lifter typically ticks right away and may go away after a bit. The ticking would be coming from the valve cover area and shouldn't really sound like it's coming from the bottom end.
If there is any way that you can get a video of the truck while it's making this noise uploaded to youtube/photobucket/picasa/etc, it would sure help in the diagnosis.
Piston slap doesn't typically make a lot of noise at idle, but can last a minute or two at higher RPMs. If it does make a lot of noise at idle, it would get worse with higher RPMs (at least that is what it has done in my experience with a few vehicles).
pitouras
Apr 7, 2010 02:54 PM
hkellogg
Jul 29, 2009 04:39 PM
