Help! Leaking Schrader valve!
Old Feb 21, 2011 | 04:46 PM
Tortex53's Avatar
Tortex53 is on a distinguished road
Default Help! Leaking Schrader valve!
Well, I just got done testing my fuel pressure. After letting the car sit for about half an hour, I decided to check for vacuum leaks with an unlit propane torch. Well, the Blazer wouldn't start - just kept cranking. It always starts right away. I look under the hood, and the Schrader valve had been spewing out fuel. The wiper motor was wet, and there was gas all over. What the heck? What do I do now? Is there a way to unstick the Schrader valve?
Old Feb 21, 2011 | 05:28 PM
Tortex53's Avatar
So, I ended up poking the valve with a little screwdriver a few times, and I guess it worked. The car started, and it doesn't seem to be leaking. It's not spraying fuel all over any more. I'll wait until everything evaporates and then see if there's any seepage.
Old Feb 21, 2011 | 05:48 PM
AJBert's Avatar
I was going to suggest a tooth pick to do what you just did, until I read you had alread done did it!
hoebob69
Performance & Brainstorming
Apr 4, 2015 06:22 PM
frabes
Jul 25, 2014 05:42 PM
dj00140
16
Sep 13, 2011 06:47 PM
chrisemery
Oct 19, 2008 11:08 AM
rdhack
Mar 7, 2008 07:28 AM
