schrader valve leak r134a
Old Mar 6, 2008 | 11:53 PM
rdhack's Avatar
rdhack is an unknown quantity at this point
Default schrader valve leak r134a
Anyone know how to repair a leaking high pressure side schrader valve leak ?r-134a System
Old Mar 7, 2008 | 06:32 AM
Default RE: schrader valve leak r134a
How bad is it leaking? I have had one leak after I have removed a set of gauges before, but I just put the gauges back on and removed them again and it didn't leak after that...
Old Mar 7, 2008 | 07:03 AM
rdhack's Avatar
Hey Kyle,
I put 3 cans of freon in before I knew it was leaking. I kept wondering why the pressure would build up then fall off quickly. finally noticed oil/dirt around that vale and removed the cover and could hear it. Only leaks though when the compressor is pumping.
Thanks,
Richard
Old Mar 7, 2008 | 07:07 AM
Hm.. Well, it probably still is leaking even when the compressor is not running, just not much. I would try to put a full set of gauges on it and flush out that line. Not sure what to do if you do not have access to a full set of gauges though...
Hope it wasn't 3 big cans! That would be a lot of refridgerant.
Old Mar 7, 2008 | 07:17 AM
rdhack's Avatar
Hey I just found aon Advance Auto web site a Interdynamics Valve Core Tool. I also seen a set of valve cores. I may drop by one of their stores this afternoon. Have you ever had any experience with these?
Old Mar 7, 2008 | 07:24 AM
First time I've ever hear of them... One thing is for sure though, you will want to recover any and all refridgerant from the system before attempting to replace a valve.
Old Mar 7, 2008 | 07:28 AM
rdhack's Avatar
10-4
It was 36 oz. of 134a that I had wasted. I would imagine that most is gone already to that great Ozone hole in the sky
hoebob69
Performance & Brainstorming
Apr 4, 2015 06:22 PM
frabes
Jul 25, 2014 05:42 PM
dj00140
16
Sep 13, 2011 06:47 PM
Tortex53
Feb 21, 2011 05:48 PM
chrisemery
Oct 19, 2008 11:08 AM
