HELP Please Fuel Tank Issue
Ok So I have a 2001 Chevy Blazer it has had about $10,000 worth of repairs all ready and i Bought it new Now when ever i go to fill up the gas tank at any gas station the Pump shuts off before the tank is anywhere near full sometimes after only $0.10 othertimes the tank gets 11$ before stopping the the Pump
Please Help ASAP with Pics if possible because i have no clue about cars but dont want to pay for the mechanic to get a second boat :P
[align=left] [/align]
Have you tried not sticking the fill nozzle into the fuel tank as far as it can go?
Some nozzles are more sensitive than others... Does it do this at pretty much any gas station?
yes it does it every where i think the hose that leades from the tank to the nozzle is loose because it is leaking alot down there i will have to bring it to the Mechanic if nobody knows what else to do
![Frown](https://blazerforum.com/forum/images/smilies/frown.gif)
Sounds like there is a problem in the fill tube. Some kind of obstruction and break in the line.
Is this a 2dr or 4dr? The 4dr has a much longer filler tube than the 2dr.
Yes it is a 4wd under the car a tube runs from the gas nozzle down to another tube where the meet they are fastned with a o shaped Ring that fits arount the tube runnign from the gas nozzle where they meet there is about a 1inch Wet spot from gasoline hope that info helps some
How many side doors does it have... I didn't ask about whether it was 4wd or 2wd...
The 4 door models have a filler tube looking like this:
![](http://i11.photobucket.com/albums/a187/swartlkk/2000%20Bravada/fuel_filler_tube.gif)
Sorry i missread that i thought you asked diffrently buy anyways it is a 4 door
EDIT: Problem has been fixed it was a leak caused by the Neck Clam Filler and Evaporative Emissions System Vent Solenoid
Blaze1forU
12-15-2011 09:27 PM
wjdjake
07-17-2011 02:06 AM
Hank3band
06-06-2011 06:44 PM
